fuel pump question
Old 02-02-2010 | 08:54 PM
Blueyerocz's Avatar
Car: 89 iroc blue
Engine: 305tpi
Axle/Gears: 2.73 posi
fuel pump question
I need to change my fuel pump soon, and wanted to know if I can put a performance pump in now. I dont have any mods done yet but will eventually. That way I dont have to change it to a higher flowing one after the mods. Or do I have to put a stock one in until then? thanks for the help
Old 02-03-2010 | 09:25 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: fuel pump question
Do a good swap now while it is out. Throw in a single walbro 255 and hotwire kit from racetronix and it will be good to 500whp or more
Old 02-03-2010 | 11:54 AM
Blueyerocz's Avatar
Car: 89 iroc blue
Engine: 305tpi
So, the higher flowing pump won't mess with the stock set-up ?
Old 02-03-2010 | 12:04 PM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
No because your fuel pressure is controlled by the fuel pressure regulator, not the fuel pump.
Old 02-03-2010 | 12:17 PM
Blueyerocz's Avatar
Car: 89 iroc blue
Engine: 305tpi
sweet thank you sir, whats the hot wire kit from racetronix that orr is talkin about?
Or does anyone have a link to that pump and hot wire kit
Ok nevermind I found not bad im gonna get the pump and hot wire kit and body ground upgrade, thanks guys
Old 02-03-2010 | 04:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah its a nice kit because it runs direct alternator current/voltage to the pump to gain even more flow since voltage is higher. Its good if you plan on doing some mods down the road. Its not all that more expensive either. Easy to install as well.
Old 02-03-2010 | 07:34 PM
Blueyerocz's Avatar
Car: 89 iroc blue
Engine: 305tpi
thanks for the info, i'm definitely gonna buy it.
Frozer!!!
01-19-2024 04:55 PM
92camaroJoe
07-29-2023 07:57 PM
RazorN8
01-07-2022 11:44 AM
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: fuel pump question
