TPI Conversion
TPI Conversion
I have convert my 1975 Truck from a 1991 Firebird GTA 5.7/TH700. After my convertion the truck ran fine for a year then I start having problems. The truck start and run fine while its cold...as soon the get hot or when the electric fan start running for about 5-15 mins the engine start shaking anf the idle goes up and down untill the engine dies and wont start after that until the cools of...
What I've done so far:
I've checked the IAC and replaced it, I did a minimum air, and adjusted the TPS.
Checked fuel presure 42psi key on and 39psi engine running.
Base timing is set to 6 degree.
No Error codes.
Could it the engine is over heating then shutdown???
No Error codes.
1 Post
Car: 1992 Camaro RS
Engine: 305 Throttle Body Injection
Transmission: Turbo-Hydramatic 700R4 four-speed
Re: TPI Conversion
i had the same problem, but with a 1992 cavalier Z24. i replaced the knock sensor and the knock sensor plug and it solved the problem.
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: TPI Conversion
I had a similiar problem with my '89, although I never did figure it out I suspected it was the ignition module overheating. I have a theory but never tested it.
Get some of that silicone grease they use and smear a goodly amount under the module
it will help absorb some of the heat.
1 Post
Car: 1992 Camaro RS
Re: TPI Conversion
it's probably either the knock sensor or the plug, cuz if they're defective and heat up too much then it reads as your engine being too hot and so it will shut off only starting when it's cold again. it's just the knock sensor or the plug that connects to it.
Sanjay
08-12-2015 03:41 PM
