Racetronix fuel pump/ hotwire kit?
1 Post
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
I need a new fuel pump as my original just died. does any one know why they say its for 88-92 and not the earlier years (mines an 87). is this a good choice for my daily driver lb9 or should i go a different route. any suggestions would be welcomed.
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: Racetronix fuel pump/ hotwire kit?
I just installed the racetronix's fuel pump and had purchased the plug & play harness always. I have an '87, like you. I have not yet installed the harness. However, I think that the harness says its for 88's and newer because the 88s started with the serpintine belt and the alternator is on the drivers side, while our alternator is on the passenger side. I think that it is simply length of the harness to reach the alternator. We will have to do a slice extension, I think.
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
The racetronix pump works great on my mild 383 on spray, and I've never had a problem, it is a loud pump but you can't hear it unless you are at the back of the car so I don't mind.
Go with the racetronix, you'll be happy.
Moderator/TGO Supporter
If you are planning on any upgrades to the engine that would require more fuel then this would be your best bet to do, even if it is a ways down the road. Better to pull the tank once because of a failed pump than when you realize that you need more fuel flow and have to do it twice.
ambainb
04-25-2016 09:21 PM
eightsixseven
08-14-2015 03:09 PM
