383 hsr fuel pressure loss
Car: 87 IROC
Engine: GM 350 soon to be supercharged
Transmission: tko 600
Axle/Gears: 3:73
using a universal holley external pump http://www.summitracing.com/parts/HLY-12-920/
26 pound accel injectors 45 psi set on the regulater works fine till the engine warms up about 20 mins in i floor the pedal and itll sputter and my fp gauge dropps dramatically down to 20 psi or so give or take 5 pounds its enough to keep it running i have heard these 2 pop up alot amperage overload or possible vapor lock any suggestions crummy fuel pump?
Car: 87 IROC
Axle/Gears: 3:73
Re: 383 hsr fuel pressure loss
using a painless tpi map sensor harness holley regulator 7730 computer chiped by motovation ......the motor is a 383 blueprintengine it doesnt happen often and i have changed pumps cause i thought that was the problem and i bought the suggested parts for amp overload put the pump on a seperate relay with a circuit breaker it only happens when i get on it when the engine gets warmed up other then that for easy driving its fine all the time
Critical Specs:
Stroke:
3.75
Rod Length:
5.7
Camshaft:
.487Int / .508 Exh & 234 Int / 244 Exh duration @ .050 - 110 degree lobe sep.
Horsepower:
405
Torque:
440
Compression Ratio:
9.5 to 1
Ignition Timing:
13 to 16 Degree Initial / 34 Degree Total
Cylinder heads:
* New cast iron "Vortec" heads
* 1.25 in. diameter valve springs
* Hardened retainers and springs
* 2.02 in. swirl-polished intake valves
* 1.60 in. swirl-polished exhaust valves
* Hardened pushrods
* 9.5 to 1 compression
Critical Specs:
Stroke:
3.75
Rod Length:
5.7
Camshaft:
Horsepower:
405
Torque:
440
Compression Ratio:
9.5 to 1
Ignition Timing:
Cylinder heads:
* Hardened pushrods
Car: 87 IROC
Axle/Gears: 3:73
26 pound accel injectors with holley regulater
Car: 87 IROC
Axle/Gears: 3:73
yea i dont know how to get it re tuned i dont have access to a dyno or anything i couldnt send the chip back but i dont know what id ask for...who did your chip?
Car: 87 IROC
Axle/Gears: 3:73
you hook it up to your laptop ? how do you burn your own chips always wanted to do that but never knew how to start it ...
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Have a look in the DIY PROM board, LOTS of good information there for getting started on chip burning.
Car: 87 IROC
Axle/Gears: 3:73
its a wild shot but what about a bad battary and alternater im running a fuel pump 2 fans msd box fuel pressure gauge tach and shift light and the harness and computer on the battery is it possible its a crummy battery and weak alternator it is always charging and thank you for your help
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
im having the same exact problem and pressure readings. i changed the regulator this morning and nothing. im going to try a new pump. 1 thing it can be on my first iroc the rubber hose that connects to the fuel pump was old and spongy and was pumping the fuel right back in to the tank.
Car: 87 IROC
Axle/Gears: 3:73
when does it happen on yours when you get on it? when its warm ? im gonna change my regulater its been good lately so idk wtf is up the pressure at start up is 44 then drops down to 41 when its warm i mean on an adjustable regulater is that normal ?
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
mines about 40 idling and drops as low as 20-25 and it gets worse as it gets hot and only notice a drop under hard acceleration. it really isnt noticed i still have decent power but im changing the pump in about a week so ill let you know what happens
Car: 1990 GTA
Engine: L98 350 Dart Heads 268XFI Super Ram
Transmission: WC T5 Hurst Shifter
Axle/Gears: 3.42 Posi
Hey Johnny
I have the exact same fuel pressure problem as you, only I have mine set to 50psi at cold start up and by the time the car is hot, it stops dropping at 34psi, did changing your fuel pump correct this problem?
Or does this problem have something to do with our headers and gas lines or even higher engine temps and fpr?
Car: 87 IROC
Axle/Gears: 3:73
i put smaller injectors when i stomp on it ...it doesnt dropp dramaticlly also i put the fuel pump on a relay both helped it fixed my problem
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i didnt fix mine yet those ****ers at summit had my msd distributor and pump on backorder since a few weeks before christmas
1 Post
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Car: 87 IROC
Axle/Gears: 3:73
yes i have that issue to i leave the cap open now just for the time being
R3500
08-17-2015 12:16 PM
92camaroJoe
08-13-2015 06:07 AM
