different sensors for the 350 tpi
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I was just reading a tech article about the 305 to 350 swap at tpiparts.com and they said that the esc and knock sensors are different for the two motors.
I did a search and found that the sensors are different.
I have been running the wrong sensors for quite a while now with no adverse affects
can this hurt my motor in the long run and should I put the right sensors in there
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: different sensors for the 350 tpi
No adverse affects that you are aware of at least..... and "yet" should be in there as well.
Putting in the correct parts is always a good idea.
