Where does the starter get it's signal from?
Old 10-18-2009 | 08:16 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
I have an '88 Trans-Am 305 TPI. I just need to know where under the dash/in the harness does the starter get its crank signal from? I know it's a purple wire, but I have a few of those and I am trying to figure out why it won't crank over now after having the dash out. I think I missed a wire somewhere, but I can't seem to find it. It started and ran fine before I had the dash out...I have a jumper on the battery as well to rule out not enough voltage.
Old 10-18-2009 | 08:23 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Where does the starter get it's signal from?
You might have screwed the VATS up.
Starter wire runs from switch at base of steering column but there are other items involved.Wire does not run straight to starter.
Old 10-18-2009 | 08:41 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
the purple wire is a 10 ga wire. it runs out of the ign switch to the neutral safety switch or the clutch safety switch.
Car: '87 Trans-Am
'88, no VATS. I have another harness/connector Im looking at right now seems like the culprit. Hopefully I can figure this out quickly.
Old 10-18-2009 | 09:17 AM
Car: '87 Trans-Am
Edit:
Alright, I did some more messing with it and found that if I put power from the battery to the 10 gauge purple wire on the "crank" fuse on the fuse panel, it will engage the starter/turn the car over and start the car. So somewhere between the key and that purple wire on the fuse panel is the issue. I really just need a wiring diagram or a trouble shooting tree to figure it out from here. On the other side of the "crank" fuse is a smaller gauge purple wire with a white stripe...I imagine that is what supplies the signal/voltage to the larger gauge wire to crank the car over. So wherever that purple/white wire gets its signal from from the key to it is where my issue lies...
Last edited by CreepingDeath94; 10-18-2009 at 08:10 PM. Reason: closed in on issue some more...
Old 10-18-2009 | 08:20 PM
Car: '87 Trans-Am
edited with some new/more info...
Old 10-18-2009 | 08:50 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Have you got power at the starter terminal on the ign switch when you turn the key?
InfernalVortex
04-20-2021 11:31 AM
3rd gen money
10-11-2019 09:57 PM
TMZIrocZ350
10-07-2015 12:09 PM
lewandom
10-01-2015 08:15 AM
SS-EXPRESS
09-28-2015 09:14 AM
Quick Reply: Where does the starter get it's signal from?
