Summit Heads? What you guys think?
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
http://www.summitracing.com/parts/SUM-152123
So tell me, what do you guys think about these heads? I don't want to go vortec(yet anyways). I don't really wanna go aluminum either. Let me know....lol.
Car: '88 Camaro (Gone...)
Re: Summit Heads? What you guys think?
I'm not a head expert at all, but those seem like pretty dang big valves for such a small runner. The price is right anyway, can't argue with that
I also can't argue with the price. I am no head expert either. Im hoping that somebody who is will respond because I am really interested in these.
I don't care for them. They have a 72 cc combustion camber. That's going to yield low compression. You should look for a head that at least has a 64cc camber.
About how low of compression?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Probably in the low 8's. Theyre basically smog heads with screw in studs and some other improvements. You can occasionally find a set of new heads off of a goodwrench in the trash. Ive tossed a set myself, and the so have a few other people on my street every now and then (should give you some idea of what they're really worth ). For free, you would probably just about get the same result. Runs, but goes slow and likes to ping from my experience.
If you actually want to get decent performance, look elsewhere.
Car: 88 Camaro SC
Engine: SFI'd 350
Any reason why you cant work over your current L98 heads? With some machine work and a good port job, they could probably run circles around those heads. The overall price would probably be about the same, or maybe a little more depending on what you do to them.
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
They're cheap--but they should be... There's so much power to be made by selecting the proper heads and cam...Actually the name of the game is efficiency... Those heads were designed for Grandma's Caprice, low performance and low compression....
I switched to aluminum heads on most everything, AFR's for the most part. I've also put together a couple projects using the Edelbrock Performer RPM package which I was very pleased with!!! They are components designed to compliment each other and will give excellent performance and retain streetability, driveability, and MPG!!!!
I guess for me it comes down to considering value more then I do price.... I want to get the most bang for my buck!!!!
