coolcant temp sensor
Old 08-22-2009 | 09:58 AM
89tpirocamaro's Avatar
Car: 89 camaro iroc z28
Engine: 355 carbed
Transmission: t-5 speed
Axle/Gears: 2.73 posi drum rear
my 89 305tpi camaro has a problem. when i first start it up( motor is cold) it drives and runs fine. when i shut the car off and go to start it again (motor is warm) it wont start. its at the shop and they tested the wires that cap on to the fuel injectors and when hot the light is very dim compared to very bright when cold. they just put in a new distributor, ignition coil so its not an ignition problem...... starting to think that the problem is the coolant temp sensor, the wire that connects to it is a little corroded and i think it might be bad itself.....someone please give me some answers so i drive my car
Old 08-23-2009 | 12:11 AM
Pocket's Avatar
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Re: coolcant temp sensor
1) Stop going to that shop
They tested for voltage across the injector plugs and noticed a voltage drop relating to engine temp
How in the hell can you relate that to a faulty distributor
2) How the hell is a CTS remotely related to a 'no hot start' issue? Faulty CTS is code 14 BTW
If the two wire CTS to the ECM is corroded and you have no code, then there is no issue. If the ECM cannot get a good reading within its specs it WILL throw a code 14
If the single wire CTS on the drivers side head is corroded or unplugged for that matter, nothing will happen relating to starting/running. Its sole purpose is to drive the gauge
Your problem lies elsewhere
Old 08-23-2009 | 01:16 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
i think he means coolant temperature sensor, not coolant sending unit
Old 08-23-2009 | 06:41 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I agree with Pocket.
ECM, ICM, and associated wiring.
Old 08-23-2009 | 06:51 AM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
When I had HOT Start issues it turned out to be the fuel pump relay >> only 20 bucks... start cheap or gank off your ECM and have autozone test it for free! Let us know...
Old 08-23-2009 | 10:13 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Test the fuel pressure at shut-off.
92firebirdguy
09-01-2016 08:53 AM
L98GTA87
10-19-2015 11:43 PM
cking99
09-22-2015 12:33 PM
corey8084
09-17-2015 03:56 PM
m00n420
09-11-2015 03:39 PM
