a little help with my application (84 K10)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: RS
Transmission: 4L60
First off, yes I know that this isn't a TG, but it is a tpi on a chevy, and I do own a TGO (member since '01, damn that was a long time ago)
anyways, I picked up an '84 k10 350 chevy, with a recent rebuild. it has a crappy old Quadra-jet on it that I have to choke on a warm day. I have a Gen I style TPI laying around and thought it would be perfect for this truck. I'm not looking to do anything much more than stock with the TPI, but I am indeed of a wiring harness, I see that Painless sells one for 450 or so, I have a chip burner so I can do the chip myself. I also have a cam shaft laying around with about .489 lift and 216/217 duration.
I'm basically looking for any advice on the best way to do this without breaking the bank (I just bought a 454 for my '91 RS)
Car: 1989 Iroc-z
Engine: 5.7L 350
Axle/Gears: Stock 2.77 posi
Re: a little help with my application (84 K10)
I guess I don't exactly know what your question is. For one, If your on a budget go find a decent harness out of a tpi from a salvage yard. No need to spent 500 on a harness. I don't know what heads your running but with the lift on that cam you will yank the press in studs out of a stock l-98 head. Some people have got away with it but if it were me just for the extra insurance I would at liest put screw in studs in and some poly locks.
You will definetly need to do some kinda tuning as that cam is a lot more agressive that the stocker.
Car: RS
Transmission: 4L60
I guess I wasn't the clearest on that.
Should I even bother with that Cam Shaft? or just leave the motor as a stock 355 with a TPI on it?
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
IROCNParts
09-24-2015 10:50 AM
dbrochard
09-19-2015 08:13 PM
