help wont hold fuel pressure
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
HELP!!! Ok I switched to 22lb injectors and It wont hold fuel pressure. If I pinch the pressure return hose it holds, I read that the regulater was bad..So I swapped it out and its the same thing...I dont get it.. someone please help!!
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: round ones "3.73"
Re: help wont hold fuel pressure
Gee. . . how did I guess???
The small piece of hose between the pick up tube and the pump is leaking.
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
x2. I bought a pos autozone pump and i had to do the job twice....ugh but i replaced the hose from the pump to the hard line as well and man what a diff. holds 42psi for a good 30 seconds then slowly falls.
Engine: shinny 350
The only way to check on that is to pull the tank. If you do, replace the 1 inch section of hose with the proper stuff. It is not just any hose and not just any fuel injection hose. I forget the exact number on it but it is not common and any joker at an auto part store will try to tell you otherwise.
I want to say it is R6 but double check that. If you buy or just look at a complete bosch unit it has the proper hose in the kit. You could look at that to verify the number. I stress to you research this yourself and dont trust just anyone to tell you the hose they have is the right stuff because odds are it isnt.
This is free wisdom. . .use it as you may!
jeff
jeff
Car: 88gta
Engine: 357
that is what it was...the rubber hose was seperating ang falling apart....changed it out and it holds pressure now....Thanks!!
Engine: shinny 350
Glad to be of help! I didnt want to see you chase symptoms.
Jeff
Jeff
R3500
08-17-2015 12:16 PM
92camaroJoe
08-13-2015 06:07 AM
