TPI emissions....i want them gone!
Old 05-12-2009, 10:39 AM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
i want all my emissions gone under my hood...can i do this without it running crappy if i block everything off? ive already takin off the smog pump,cruise control and all the A/C.
Old 05-12-2009, 05:43 PM
TGO - 10 Year Member
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
re: TPI emissions....i want them gone!
You'll have to disable the EGR in the prom to prevent it from throwing a code and it's been quite a while but I believe there's something else that should be changed for the A.I.R. pump.
Old 05-12-2009, 05:50 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
why bother? there really isnt that much performance gains for the amount of work and headaches.
Old 05-12-2009, 05:52 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
No there isn't. Most people just do it for the ease it provides of working on the engine.
Old 05-12-2009, 06:40 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
yeah well i just want them gone for a cleaner look and for work ease
Old 05-13-2009, 06:52 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
The engine with all its stuff on is easy to work on. The things that are a tight fit under the hood have nothing to do with emissions.
Old 05-13-2009, 07:11 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
The AIR Diverter Valve on my car gets in the way sometimes, but it comes off with two bolts removed, the plastic cover over the connectors removed, then de-mate the connectors. Removing and re-installing the valve adds ten minutes to the job.
Bill
Old 05-13-2009, 02:25 PM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
i had to delete the stock smog pump to install a corvette short aluminum water pump
i had to delete the lower half of the serpintine bracket on the side infact
nice being able to have a 25 dollar aluminum water pump compared to a 80 dollar one
Old 05-15-2009, 05:09 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TPI emissions....i want them gone!
First, This is a pretty common topic.
Second, its completely illegal to remove the emissions devices on a street car in the United States. What you've basically said is the current laws are not enough to stop you, so the lawmakers need to write tougher laws to punish us all. Thanks!
Old 05-16-2009, 06:00 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
oh HA HA..some ppl really are just environmental freaks...i dont think its a big deal...maybe if everyone else started doing it but the way newer vehicles these days are designed emissions wise thats not a problem. i just dont want all that clutter under my hood so it doesnt look like ***.
Old 05-16-2009, 06:05 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Its not clutter, the complexity looks good to me.
Old 05-16-2009, 06:19 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Originally Posted by gcgarner
Excuse me gc, but your car is one of the finest examples Ive seen of
a smog compliant underhood gem.
Old 05-16-2009, 06:27 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
lol but not all cars look like that under the hood...try getting to the exhaust manifold to change it or taking off your pass side valve cover.
Old 05-16-2009, 06:32 PM
TPI's Avatar
My basic point was they can look like that easier than you think!
But yea, you got to finesse things alittle more when working on it.
Old 05-16-2009, 06:59 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
The best reason to leave it on there is resale value. An unmolested car with all it's original equipment will be more valuable. If you do take it off, save it.
Old 05-18-2009, 11:21 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
When the law makers get done, we will all have electric cars and these oldies will be bought up and crushed for a gov rebate. Just hope that they will be old enough to be antiques and not just junk.
Old 05-23-2009, 09:58 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
oh well i have my to drive it and enjoy it not save it hidden away for someone else to enjoy someday when im not around ha
stalkier
12-06-2015 11:25 PM
ChaseDale3and8
09-01-2015 01:49 PM
Keith5
08-27-2015 04:37 PM
theurge
08-21-2015 12:46 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: TPI emissions....i want them gone!
