Need Help Identifying Fuel Pump '87 Camaro 305 TPI
Car: 1987 Camaro IROC-Z
Engine: 406 sbc
Transmission: T5 for as long as it holds together
Axle/Gears: Limited Slip.. 3.08
Im trying to find out what the gph is on the stock fuel pump in my 1987 Camaro IROC-Z 305 TPI. Im installing a fuel pressure regulator and im having a few leak issues. I have an installation chart refrencing the gallons per hour flow from my stock pump to what I will require for size in my return line. any help identifying what the flow rate of my fuel pump would be???
Re: Need Help Identifying Fuel Pump '87 Camaro 305 TPI
beachrodder
08-25-2015 08:05 AM
