P/s pump and pulley fitment question
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
I'm thinking about purchasing this particular power steering pump (GM type II) with a .661" shaft
and this 6.5" serpentine underdrive p/s pulley to mount to it
but I need this mounting adapter called a 'flange mount' which fits pumps with a .662" shaft to mount the pulley to; its a press-on type of adapter.
My question is bieng that its press-on and that theres a .1" difference in diameter, would this flange mount still fit the p/s pump shaft?
Thanks in advance,
Phoenix
Thanks in advance,
Phoenix
Re: P/s pump and pulley fitment question
just call PSC they should have a pulley that works with out the adapter, I used one of there pulleys when I put my second pump in place of my AC compressor
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
I already went with a specific type of pulleys to install on my car (seeing if they really add hp's ) but I'll keep that in mind if all else fails. I'm sure someone has had experience installing press-on type pulleys; bieng that the p/s pump shaft diameter is .662" and the flange mount adapter .661", can I still get a good fit?
Thanks again,
Phoenix
Thanks again,
Phoenix
evilstuie
01-09-2020 08:29 PM
Navy8125
08-22-2015 07:13 PM
mcquigg
08-13-2015 02:26 PM
Street Lethal
08-12-2015 11:33 AM
