l98 losing spark
Car: 90 formula
Transmission: auto
l98 losing spark
been losing spark or getting weak spark.
replaced the distributor it self, pick up module, control module, cap and rotor, plugs and wires.
but it doesn't bog out any more but sometimes it runs good and sometimes it doesn't.
when its running good when you take corners or crank it up it starts really running crap.
takes long to start up too.
my question is what else should i check besides the coil. that's my next step.
thanks its a 90 Pontiac firebird with the 350 tpi
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: l98 losing spark
Car: 90 formula
Transmission: auto
i know its losing spark. you can smell the fuel and when your behind the car you can smell unburnt fuel /fresh fuel. runs kinda good or runs really bad at times.
Car: 90 formula
Transmission: auto
the connector to the coil is pretty chewed up to the point where it needs to be replaced.
and im 99% thats what it is.
just gotta find one locally.
Car: 90 formula
Transmission: auto
yeah that's what i have. the connector for the coil doesn't have enough wire on it to fix it.
i wish it was just the coil. cheap and easy to swap out.
RedLeader289
05-28-2019 01:47 PM
