tpi cleaning
Car: 87 Camaro
Engine: 5.7 350 TPI
tpi cleaning
does anyone know how to clean and what is safe to use to clean the throttle body. i have a tpi on my 87 5.7 camaro.
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: tpi cleaning
Or throttle body cleaner. It used to be that not all carb cleaners were O2 sensor-friendly, although that's probably changed.
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: tpi cleaning
Use throttle body cleaner. Carb clearer can strip the protective coating off of some throttle bodies.
Re: tpi cleaning
well i just said it to be quick. most of the cleaners youll see when going to the auto parts store will say, throttle body and carb cleaner. so i guess aslong as it says throttle body your good.
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Engine: 5.7L/350
Re: tpi cleaning
You're taking a big risk spraying 20 y/o electrical connections with a pressure washer.
mdtoren
08-16-2015 05:45 PM
Sanjay
08-12-2015 03:41 PM
