FYI: Stock Serpentine Pulley Diameters
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Hows it going? I've searched all over this board for the diameters of the stock serpentine pulleys for reference purposes but found nothing so I thought I'd post them up:
Crank - 7 3/4"
Water Pump (long) - 6 1/2"
Power Steering - 6 1/2"
Alternator - 2 1/2"
Later,
Phoenix
Crank - 7 3/4"
Alternator - 2 1/2"
Later,
Phoenix
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: FYI: Stock Serpentine Pulley Diameters
Great Info. Any idea if I can get a shorter belt and reroute it when I delete my AC or do I need an AC delete pulley?
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
I've heard you can only reroute the serpentine belt when removing the smog pump (correct me if i'm wrong). As for the a/c delete, you're going to have to use the a/c delete pulley along with the shorter belt. hope this helps.
Later,
Phoenix
Later,
Phoenix
Car: 1986 iroc
Engine: 350 .060 AFR HSR XFI280
Transmission: transgo 700r4
do you know how tall the stock tpi crank pulley is?
i was putting a paxton sc on my car and try to use a tbi crank pulley since i had underdrive pullies before, but its looks like the pulley needs to be like 1/4" taller so it can align with the rest of the accessorie's pulleys...
Car: 1986 iroc
yeah well it turns out tbi truck pulleys arent the same as tpi. tpi's have a bigger offset
evilstuie
01-09-2020 08:29 PM
evilstuie
04-14-2016 08:52 PM
Navy8125
08-22-2015 07:13 PM
mustangdmurder
08-21-2015 07:17 PM
