Can't Find Vacuum Leak?
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
My car has a vacuum leak by the ninth injector, but I can't figure out exactly where it is coming from. The gasket on the intake is the correct one for the ninth injector also. Did anyone here have a problem like this? What else should I check?
Car: 1989 Formula 350
Engine: building a 383 as of Feb. 09
Transmission: 700 R4, B&M shift kit
Axle/Gears: 3.23?
Re: Can't Find Vacuum Leak?
You could try an ultrsonic leak detector. You might be able to rent one from an auto shop. That would find your leak for sure.
Car: 85 Iroc-Z
Well I thought that the ninth injector might not have been sealing itself against the runner so I changed it with another one I had and it fixed the problem. Thanks for the help.
