Edelbrock TPI system: thoughts??
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
What does everyone think about the Edelbrock TPI baseplate and Runners??
I bought some Bosch design III 22 lb injectors and went to install them... and well... something happened and i need a new baseplate and runners.
What do you guys think about the EBrock system? is there a better setup that costs the same and is better??
Thanks guys!
Thanks guys!
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
Re: Edelbrock TPI system: thoughts??
Review the attached article entitled "Ten Times The Torque". It compares several base plate and runner combinations on a TPI set up including the Edelbrock system. Hope this helps somewhat.
http://www.compcams.com/Community/Ar...?ID=1737510521
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
the big mouth and runners and 52mm tbody
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Car: 87 Trans Am
Transmission: TKO 600
I went with the Edelbrock Base/Runners. I can't tell you about the Performance increase because I changed too many other things at the same time. There is a lot of material to port them out. I ported out the runners and smoothed out the base I also matched the plenum to the runners. I don't have any complaints. I used a cheapo Harbor Frieght die grinder with a speed controller with some good carbide burrs and some flapper wheels.
I ported farther down the runners after the pics were taken.
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
In the pics I ported farther down the runners after the pics were taken.
theshackle
09-17-2020 08:26 AM
CarGuyDennis
137
12-06-2016 11:02 PM
86IROC112
08-17-2015 02:00 PM
Sanjay
08-12-2015 03:41 PM
