1986 corvette heads
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
1986 corvette heads
are they better peformance whys than stock tpi camaro heads or are they the same ?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1992 Camaro Z28
Engine: 350ci
Re: 1986 corvette heads
If you get corvette heads make sure they are the 113's. The '88 and later heads are a better design. I'm running a pair of ported vette heads with 2" intake valves and 1.6" exhaust valves. They are 50 pounds lighter then the camaro heads, and when worked on like mine are they are worth about 50 horsepower. In stock form they are just slightly better than the camaro heads. The egr is a different design that requires the corvette intake manifold and an external egr pipe.
If you do go for the 86 vette heads, note that the early ones were cast iron and the later ones were Alloy (128's) but as stated above the '88 113's are the better ones.
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
i was just wondering the benefits because i can get a pair for 90 bucks
Car: 86 iroc
Engine: 350 vortec HSR
Axle/Gears: 370
I have a 350 GMPP motor. Wondeirng if these will direct swap on. And would the heads work with a HSR?
the 14101128 86-87.350.Aluminum,58cc,angle plug
check my build thread for specs on my current setup
https://www.thirdgen.org/forums/tpi/...-build-up.html
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I've seen them at http://forums.corvetteforum.com/c4-p...ale-wanted-55/ several times.
You might want to just watch out for them. I've seen several sets at descent prices on ebay also. Make sure seller has great feedback.
Car: 1983 G20 Chevy
Transmission: 4L60
Late model ZZ4 heads are 113 casting TPI heads, with springs for .510" lift and factory port work. They are a cleaner casting than the stock corvette pieces and WORTH finding. They won't cost you any more than a set of 113 stock Vette heads.
ambainb
04-25-2016 09:21 PM
Pilotrick50
09-02-2015 12:48 PM
