worth getting custom tune
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i was wondering would i benefit alot from a custom tune... my computer is trying to "fight" with my cam's idle and the computer is trying to make the idle as smooth as possible.. there is a guy i know that specializes in l98 tuning and i was wondering could he fix this.. here are my mods... my car sounded mean a week ago... here is a vid
http://www.youtube.com/watch?v=YmAOjTj03yU
it sounded good.. but every since i gutted the cat is does not sound like that anymore it has more of a stockish idle..... could the tuner fix that problem..... i needed a upgraded computer tune so any replies would be helpful....
5.7 350 factory l98 engine
Rebuilt ported l98 heads
Cranes 2032 cam 452/465 214/220 112lsa
Cranes matching springs
SA performance double timing chain
Cranes Adjustable fuel regulator set at 45psi
Flowmasters 80’s series 3.5 inch catback
Catco High Flow Gutted converter
Custom 3 inch built Y-pipe
Heated O2 sensor
Hedman Longtube Street headers
Ported and Siamesed SLP runners
Ported and Siamesed Plenum
Ported Edelbrock High flow Intake
SVO 24lb Injectors
SLP cold air intake with K&N air filter
SLP airfoil
IAT relocated to SLP air box
160 thermostat
Throttlebody Bypass
EGR delete
Heater valve delete
Air/smog delete
LT1 Starter
Heavy duty flywheel
MSD 8.5 super conductor wires
Accel super coil
Performance radiator
Pro built 700r4 rated at 500 horsepower
B&M shift kit
Tranny cooler
2500 converter
High flow water Pump
Heated O2 sensor
SVO 24lb Injectors
SLP airfoil
160 thermostat
Throttlebody Bypass
EGR delete
Heater valve delete
Air/smog delete
LT1 Starter
Heavy duty flywheel
Accel super coil
B&M shift kit
Tranny cooler
2500 converter
Car: 86 T/A WS6/Future project
Engine: 350 TPI/ Pontiac 455
Transmission: 700R4/TH400
Axle/Gears: Posi.
Re: worth getting custom tune
well i know when u take the cat off u run rich. dont know if that is a problem though.
Hello fellow NCer!!!!!!!!!!!
How do you know your computer is fighting the cam? The car sounds great, and if it's running well, don't mess with it.
Could you maybe sqeeze some horses out of it with a tune? -sure, but if it's running well.....you've gotta make a choice. You've got enough mods to easily justify a tune, but again, you might not need it.
I have a ZZ4 cammed L98 with exhaust etc. etc. and my car ran great for years. I finally got a tune, and I still tinker and go back and forth between tunes, trying to see what I like about each tune in hopes of maybe getting a third "better" tune.
....if you've got a friend who's capable, I'd probably just go ahead and do it!
hey... i can tell because the cam starts to loop by the computer quickly tries to smoothen it out and raise the idle.... before with the un gutted cat the computer didnt fight the idle and it would sound mean..... it doesnt even sound like the video anymore.... we played with fuel pressure and i dont know where to set it at..... considering i have 24lbs injectors we set it at 40psi... is that too low... should i raise the pressure up.... also its running rich now because of all the modifications ne ways..... i just thought i would benefit from a tune.....
1 Post
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
If your running all this on the stock tune, then you definetly should get a custom tune. Especially since you changed the injector sizes and deleted emission devices.
Heated O2 sensor
SVO 24lb Injectors
SLP airfoil
160 thermostat
Throttlebody Bypass
EGR delete
Heater valve delete
Air/smog delete
LT1 Starter
Heavy duty flywheel
Accel super coil
B&M shift kit
Tranny cooler
2500 converter
Heated O2 sensor
SVO 24lb Injectors
SLP airfoil
160 thermostat
Throttlebody Bypass
EGR delete
Heater valve delete
Air/smog delete
LT1 Starter
Heavy duty flywheel
Accel super coil
B&M shift kit
Tranny cooler
2500 converter
The biggest issue outside of performance is going to be the Cam and injectors. The computer may be able to compensate for the cam properly, but the new injectors are a constant, and it just won't know you've made a change unless you tell it.
All the other mods should be able to be handled by the computer. ...so yeah, due to injectors, and possibly the cam, a tune would be a good idea.
Now as for performance, yes, without a tune, you're leaving power on the table. A tune would certainly help. Not trying to be confusing, but I just like to point out the difference between needing a tune to gain more power, and needing a tune to make the car run properly.
yes im running all that on a stock tune.... and abubaca i understand what your saying... i want the tune mainly because i want the car to run properly and at its best but getting performance also from this tune would be a bonus... im more than satisfied with my power increase... this is my daily driver and i dont eva plan on racing it.... when i get this tune i just wanna see what it runs down the quarter mile and get a dyno sheet and thats pretty much all the racing its gonna see.... basically all i wanted is a nice mean sounding trans am thats a fun daily driver... i have achieved that... now all i need is to get this thing to run right and paint job and im done... the interior is already mint looks brand new..... the guy who is doing my tune said its gonna be 400 dollars.... he will use his laptop and place it on a dyno to tune the car.... burn a new chip for me.. he specializes in l98 tpi engines.... so do you think 400 is a good deal..... he lives in greensboro so its not really that far from raleigh.....
so what do you guys think i will be making to the wheels as far as horsepower and torque goes..... he said that he could probably get an extra 10hp from the dyno tune.. he said thats not counting the tune that will be doing on his laptop...
morrow
01-13-2024 12:29 PM
Hotrodboba400
12-10-2019 07:07 PM
