Good cam for TPI
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Good cam for TPI
http://store.summitracing.com/partdetail.asp?part=CCA-08-423-8&autoview=sku
350 TPI, I want lumpy Idle.
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Good cam for TPI
With the stock TPI intake, that cam would be a bad choice. About the time the cam gets to its happy rpm, the stock intake will choke it.
Also, you'd need very competent tuning to make that cam behave at all (that goes for ANY lumpy sounding cam in the L98).
Car: 89 IROC Z-28
Engine: 5.7
Transmission: A4
That cam duration (224 / 230) looks just like the one in my 355 (only I'm running a bunch more lift and more compression) I know that "Lumpy" is most definitly a relevant term, but that cam is not at all lumpy in my engine. Maybe KEVIN 91-Z28 will chime in here. He did all the tuning on that engine.
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
I agree with LG4Bird, with the stock intake this cam is going to be a mismatch.
Car: 89 IROC Z-28
Engine: 5.7
Transmission: A4
Or just go the really economical route and pull a couple of spark plug wires off. That always results in a pretty nasty idle!!
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
get a crane 2032 cam.. its in my 350 tpi it has a lumpy idle but i have alot of supporting mods.... this cam can go into a competely stock 350 tpi with no problems.. but i suggest replacing the springs that match with this cam.... look at my videos and you will see my mods
http://www.youtube.com/watch?v=YmAOjTj03yU
http://www.youtube.com/watch?v=Yja12...eature=related
I've got that cam in a carbed 350.
Sounds great at idle. Decent lope and I can keep the idle speed around 700 rpm. Attracts a bit of attention too.
Can't comment on the compitability with the TPI though.
And I can still mange over 20 mpg on the highway.
Car: 1983 G20 Chevy
Transmission: 4L60
The 110*LSA thing depends on duration. On some cams the 110*LSA still has very little overlap. Thinking of the peanut cam on a 109*LSA. I have run the Crane 272H10 in a TBI motor and it got along with the stock computer just fine and ran even better once I dialed it in.
The cam in my Van is Reed Custom roller on a 110*LSA, I had the same cam in the 305, but I would consider myself an established tuner and quite frankly, with its limited duration @ .050, its not a problem.
It has a very healthy fuel requirement at heavy loading/higher rpms, but the cam, ported vortecs, and edelbrock base really let the air in. I am running stock runners, because this application needs TONS of torque in the 2,600-3,600 rpm range and to get this, I am willing to sacrifice the torque curve up high and top-end HP.
This is how quick the 6K rev-limit comes up, even with 3.08 gears, 29.5" tall tires, a sub-2,000 rpm stall torque converter, and 5,500 lbs of vehicle weight.
He's not talking about a small cam with a 110 LSA like your small cam. He's talking about a big cam with a 110 LSA, hence my comment that the computer will be easier to tune, it'll idle better, and get better gas mileage with a 112 or higher LSA. The trade off is 10 less HP at peak power above 5000 rpms. Big deal.
Car: 1983 G20 Chevy
Transmission: 4L60
I know he is not, thats why I said a small cam. The OP should really consider going with a smaller cam if he has stock heads and stock runners, even more so if he is running the stock exhaust manifolds and exhaust setup.
My point was the 112 or higher LSA is not always the best route. Wider LSA cams can cost you up to 20 ft/lbs through the mid-range, I've personally dyno'd the difference between 110 and 112 on an otherwise identical cam. The 112 LSA cam lost 20 ft/lbs @ 3,500 rpm vs. 110 LSA. You are right though, you do give up about 8-10 hp above 5,000 rpm. How often are you above 5,000 rpm on a stock head/runner TPI? Seldom at best and even when you are there, not much is happening. The narrower LSA makes the idle thump a bit more, which ultimately is what I believe the original poster wants. As long as he is not wanting a pro-stock idle, just a nice muscle car sound, something around 208/214 @ .050 on a 110* LSA will be all the TPI needs to be effective. This cam easily pulls 5,700 rpm+ in my TPI 350.
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Hey FAST355, have you ever run the LT1 or LT4 Hot Cam in your TPI to compare them to the cams you are currently running?
I am asking because I have seen both of those cams run very well in mostly stock TPI and TBI applications in the last 10 or so years. Not much tuning required it seemed, but we didn't use all the fancy stuff out there now and we didn't do any dyno testing. Just street driving but boy, did it run good!
Car: 1983 G20 Chevy
Transmission: 4L60
Car: Faster
Engine: Than
Transmission: You!
I have the same cam only with a 112 LSA, but ported heads/intake etc.. etc.. with manual tranny, many hours of PROM tuning....
http://www.youtube.com/watch?v=kfLWpAy0c1o
Sanjay
08-12-2015 03:41 PM
