Map Sensor
Map Sensor
Does anyone out there know if my map sensor can be the sole cause of not being able to accelerate causing the engine to bog and try to die. I have went through most every thing you can check and replaced Ing. mod. cap rotor wires plugs and TPS even found my ESC wire discon. and reattached yet all still the same. I guess Im hoping to here someone with same prob. that had sucess with its replacement. Thanks for any help, George.
efiguy
09-27-2015 01:30 PM
