Starts runs but won't accelerate
1991 v6 checked fuel psi and timing all ok no codes can this be a ing. module allowing it to run but bog under acc. or do I need to be looking more towards TPS sensor or ecm/ prom problem, my cooling fan came on right at the second the cold idle valve kicked off, to soon engine not even hot yet and when I put paper clip in to check codes fan came on is that normal?
theshackle
03-05-2017 06:37 PM
92camaroJoe
08-13-2015 06:07 AM
