voltage problem need help
Old 10-01-2008 | 10:47 PM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
heres my problem: I i just put in a new battery its 2 days old and got my alternator tested at the local parts store and they said it was fine and i did all this cause my volts were low and didnt go up so i figured it was the alternator and it turned out to be the battery so when i put the new one in and cranked it up the volts still stayed low befor the battery went out the volts red 13 well like right above the 13 and i did put a mechanical fan switch so you think i could have touched or moved something where it caused this idk what else to check so any sugestions would be really great or any ideas of what i should check thanks in advance
norcalz28
Northern California
26
12-07-2016 12:49 PM
middian
09-05-2015 01:42 AM
andy74
09-03-2015 08:41 AM
greenyone
09-02-2015 03:39 PM
RyanJB
09-02-2015 01:27 PM
Quick Reply: voltage problem need help
