lookin for a cam for the TPI
1 Post
Car: 91 RS
Axle/Gears: 3.45
is there any cams out there that we can put in our 350 TPI's? nothing too aggressive or outrageous something wit a little more lift. also, would i have to do anything with the ecm or anything if i do this? i wanna cam my 350tpi to give it more power while its completely out since im doin my swap right now. thanks all in advance!
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: lookin for a cam for the TPI
I use to have the ZZ9 camshaft from TPIS. It gave me a little more power and had max lift for my heads. I still maintained 24 mpg
1 Post
Car: 91 RS
Axle/Gears: 3.45
thanks!
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
You can also look into comp cams 08-501-8. However, you should consider replacing the valve springs when ever you consider upgrading the cam, and also making sure that all clearances are met. It is worth the extra few hundred bucks.
Plus, whenever upgrading the cam in a TPI it is always a good idea to re - tune the computer, even if the cam you are putting in is computer compatible. It is the only way you are going to get the most out of the cam upgrade.
1 Post
Car: 91 RS
Axle/Gears: 3.45
Engine: 305TPI
Your fuel economy will also improve alot after a tune.
1 Post
Car: 91 RS
Axle/Gears: 3.45
well your the man then! lol. im gonna cam it (zz9) and then i guess we can work something out. would i have to actually drop it off with ya? just wondering how your process works, thanks a mill
1 Post
Car: 91 RS
Axle/Gears: 3.45
i just pulled up the zz9 cam and its almost 4 big ones! didnt know it would be that much ive seen dozens of cams range from 150 -200 wtf happened here?
Engine: 305TPI
I am by no means an expert, but I think that these things should be considered before throwing a bunch of money on a camshaft. Anybody that is more knowledgeable in this area please, feel free to step in and shed some light on this matter.
1 Post
Car: 91 RS
Axle/Gears: 3.45
ha yea i saw that for sure, the heads are stock 350 tpi heads not sure what the specs are on them but i should have valve clearance with stock should i?
oh, 200 isnt bad at all so i can go to GM and order a new one from them?
http://www.sdpc2000.com/product/1018...rCamshaft.aspx
Here's your part number and price from Scoggin Dickey. Ignore the part about "not for computer engines", it works just fine.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Sorry, but that cam won't work with stock heads without machining.
Or Manley springs and retainers.
Max lift is .460
That one is .474-.505 with 1.5 rockers
The ZZ9 cam is 212-224 @.050 .495-.510
Max lift is .460
1 Post
Car: 91 RS
Axle/Gears: 3.45
this is a bummer i guess i cant cam my 350 unless i get a set of heads but i dont know which ones go with the zz4 cam.
1 Post
Car: 91 RS
Axle/Gears: 3.45
ok i did some research and i might just go with this comp cams 12-388-4
its got .425 lift and .440 exh
so it should fit my stock heads and it says for TBI crossfire and TPI engines, 350 and all that.
if someone says this isnt gonna work im going to punch a hole in this computer screen!
That Comp 12-388-4 is a flat-tappet cam. Do you have a flat-tappet engine or a roller-cam engine? Roller cams are better and are worth the extra cost.
Don, even with the Manley stuff you cant use a .500" lift cam with the stock heads? Oops, I guess I have been giving out bad info.
1 Post
Car: 91 RS
Axle/Gears: 3.45
wow i thought they were all hyd roller. hmm well i guess im screwed. ahhh i dont even care anymore on a cam. if anything ill just call em and tell em what i got maybe they can grind me a cam for my stock motor and heads.
not to mention at this point i need to get my messed up wiring harness FIXED so it can work before i think about a freakin cam. thanks for the info even if it was wrong right, lol.
But why put a .500 lift cam in a grossly junk heads?
So, put in the ZZ4 cam and use the Manley setup.
1 Post
Car: 91 RS
Axle/Gears: 3.45
ok i see well i can go with this set up, and i understand about the heads but ill just go back in there and get some AFR heads or trick flow. something better. i just wanna cam it while its out, i can always work the heads from the top even though the block is in. thanks don. oh one more thing, the stock 350 heads are L98 correct? thanks again
ambainb
04-25-2016 09:21 PM
Sanjay
08-12-2015 03:41 PM
