damaged TPI wiring harness
Car: 91 RS
Axle/Gears: 3.45
i got an engine and wiring harness from the wrecking yard, a 350 tpi, and now that the 350 is about to go in i find out that the harness is damaged. these guys didnt take anytime to take it out they just ripped it all out, and most of the prongs are bent. soooo should i buy an aftermarket one? or is there a place out there that can replace it somehow? any info would be appreciated guys, thanks!
Car: 91 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: 373 posi disk brake
Re: damaged TPI wiring harness
there is a race shop here in elkridge md call AutoFab they redid my harness and i never had a prob with it... you may have to mail it but it only took the 3 days to do it....
http://autofabcart.net/about-us.aspx
there is the link
there is the link
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
get ahold of EFIconnection. The owner is a board member and he has redone and I think made whole TPI harness.
Very nice guy!
Very nice guy!
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Then inspect it thoroughly.
If you have some bad con. you can replace them now.
I have purchased stuff from www.tpiparts.net
Good quality parts and great prices.
Car: 91 RS
Axle/Gears: 3.45
take the harness and set it up on a table.
oh does efi connection have a web addy?
Engine: 350 S-TPI
eficonnection.com
looks like its under construction though. Try messaging s10wildside on here, thats the owner.
Car: 91 RS
Axle/Gears: 3.45
Car: 91 RS
Axle/Gears: 3.45
ohhhh man, not seeing how this can be replaced....the part where all the wires come together and plug in (like under the master brake cyl) that whole thing is F----D! looks like some one took come plastic explosives and blew it off. or someone had a bad day..... buncha if you ask me.
so all those wires would have to be re connected im guessing and thats a lotta wires it would be so thick it prolly wouldnt even fit. unless some one is a skilled surgeon with wire splicing.
Sanjay
08-12-2015 03:41 PM
