paper-clip trick not workin to read codes..HELP
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
So i have done the paper clip trick befor to read codes and it works great and never had a problem. well over the summer i pulled my intank pump along with my highflow inline pump and did a walbro 255 intake pump....now when i turn on the Igntion my fans kick on as soon as the pump is done priming and my check engine lite is on. If i try to do the paper clip trick it makes no difference....
I have gone through all the steps i took when doin the pump and pullin the old inline relay and wires and all seems to be fine. I do have my coolent sensor unplugged cus i broke the connector when puttin my LTs in a new connector is on order tho! How do i get the paper clip trick to work??
