How did AIR injection connect to dual-cat systems. Interested in retro fitting.
Car: 2000 BMW M5
Hi guys, can anyone tell me or diagram how the air injection lines from the smog pump connected to dual cat systems? I am going to run a dual exhaust with dual cats, and I am going to keep the air injection system (not because I have to, the car is exempt, but I want the AIR system active and functional)
Did the dual cat cars get a different AIR selector valve assy. with two outputs, one for each cat, or did it tee the AIR output to the catalyst after the selector valve?
thanks
STeve
thanks
STeve
1 Post
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Re: How did AIR injection connect to dual-cat systems. Interested in retro fitting.
Pretty much the same as a single cat but the AIR pipe to the converter splits and goes to both. I have a dual cat Y-Pipe I could send you a picture if it would help.
86IROC112
09-07-2015 01:37 PM
BurlyChev
08-22-2015 01:52 PM
