Neat looking TPI intake!
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
Car: Faster
Engine: Than
Transmission: You!
Re: Neat looking TPI intake!
By all means, please correct me if I'm wrong, but the 2.8's would actually be classified as MPFI (Multi-port fuel injection)...
So dose my mazda come to think of it! It has the variable resonance induction system as well so that makes it VRISTPI.
Most modern engines use equal legnth runners and lots of older motors do too.
And dispite all the marketing hype surrounding the TPI's back in the day all motors use intake runner tuning to determine the output of the motors.
Even if it isnt the primary concern of the design the runners allways affect the power/torque curves.
Car: Faster
Engine: Than
Transmission: You!
Well, there is a reason that GM named the 2.8/3.1's MPFI and not TPI (besides marketing). GM also named the 96-98 Chevy truck vortec 350's (CPI) or central port injection.
So I guess this poses a question......
What exactly characterizes an intake manifold as (Tuned Port Injection)?
On a side note:
The lambo TPI intake is pretty cool with the two throttle body design! Notice the size of the runner tubes are pretty close to the runner tubes of a stock chevy TPI. What makes this interesting is the lambo cylinders are way smaller (the above motor is only a 4.8 liter even though it is a 12 cylinder) and it still has TPI size runners or slightly larger with 2 throttle bodies.
Just goes to show you the benefit of bigger runners/throttle body/lower intake manifold even on a stock motor.
On a side note:
Look at it this way: All cakes are made in pans, right? But I've never had a "pancake" for my birthday, ya know?
Car: '89 IROC-Z
Engine: LSx
I think everyone is missing the point. Yes alot of old/modern vehicles use runners of equal length, but in Tuned Port the runners are "tuned" (hence the name) to a specific length for a certain performance quality (****loads of low end torque on the LB9/L98's). Yes Chevy dubbed the name "Tuned Port Injection" but there is many variances that are similar. And for the record the MPFI on the 2.8/3.1 f-bodys was also a tuned runner system. If you note to some GM manuals they even refer to it as "TPI". Just my
OK, whatever. You put a carb spacer under you carb, and technically you've "tuned" it. It IS in fact a "port", and you could argue that the jets are under pressure and they "inject" fuel. That's not really too far of a stretch.
From here on out, all cars ever made with gasoline engines are "TPI". Forget what I said about 85-92 F bods with L98 and Lb9s. I've been corrected.
.......or we can stop splitting hairs on technicalities and call TPIs what they are. LB9 and L98 engine EFI intakes.
Older carbed motors typicaly had short runners and if they were performance oriented they naturaly made peak power high on the tach.
So called "tuned" intakes only became practical with the introduction of port injection since long runners on a wet intake tend to suffer at lower RPM because of fuel falling out of the air. That kinda cancels out the low end benifits of long runners.
Car: 85 vette/87 TA
Engine: built 383/350 tpi
Transmission: built 700r4s
Axle/Gears: 3.45 dana 44/ 3.27 9 bolt
You are trying to make TPI a classification. I believe the tpi is already classified a MPFI.
Car: '89 IROC-Z
Engine: LSx
I give up, I thought ford people were ***holes, all I'm trying to say is dont chop someones head off for calling another car companys set-up similar to tuned port.
You dont need to be a ****head about it, I just dont see why people have to get argued with when the original post was just lookin at a cool induction set up.
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
ok as said b4 TPI is not a classification its a name. TPI IS MPFI.....just like Posi traction is a LSD....Chevys special name for it nothing else....I dont know of any intake manifold where the runners were just made with no planning and adjustments there for like said before intake manifoldss are all tuned....
1992rs/ss
05-19-2020 07:02 PM
LT1Formula
20
11-14-2015 12:02 AM
Sanjay
08-12-2015 03:41 PM
