need help findin a fuel fitting for -6an braided lines!
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
i have all the fittings needed to swap to braided lines other then the ones that go to the fuel rail. i know they make the two lil fittings male to male but i got some 12" hard lines that extend the fuel rails down by the stearing pump that i would like to use and the ends are both male in stock sizes. so im lookin for what like 14mm female by -6an and 16mm female by -6an? i cant find them tho can anyone help me out!!?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: need help findin a fuel fitting for -6an braided lines!
What are you trying to do exactly?
Car: check
Engine: check
Transmission: check
Earls (Holley) part numbers:
9894DBH Female 14mm x 1.5" to -6: Fuel Injection Female "O" Ring Seal
9894DBJ Female 16mm x 1.5" to -6: Fuel Injection Female "O" Ring Seal
I believe there are pictures on Holley's site. Just double check that these are what you are looking for. These pieces fit the hard lines coming off of the frame.
RBob.
RBob.
AkDrifted
08-17-2015 08:45 PM
