Bad Injectors???
Old 07-27-2008, 08:29 PM
  #51
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: Bad Injectors???
Originally Posted by t/agta
are lt1 injectors a direct swap? I will get it programmed into the chip that they're 24s not 22s, but are they the same size as stock l98 injectors?
lt1's use a 22 till 94 then 24 when they went to sequential injection// same as l98 to 92
Old 07-28-2008, 01:40 AM
  #52
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
I would go with the Bosch III from FIC any day..
Old 07-30-2008, 07:55 PM
  #53
TPI86TA's Avatar
Car: 88 GTA
Just received my 22 LB injectors from FIC. I should be installing them this weekend if all goes well.
Old 07-31-2008, 12:46 AM
  #54
Theking's Avatar
Car: 1989 IROC-Z
Good, keep us posted about the change
Old 08-17-2008, 10:29 PM
  #55
TPI86TA's Avatar
Car: 88 GTA
Well i installed my injectors into the fuel rail and installed the rail in the intake so far. This weekend i should be hopefully replacing the fuel pump assembly to cure my leak issue and if all goes well maybe ill get her running. When i talked to Jon from FIC he said i dont use the "c" clips on the Bosch design III injectors.
Old 08-18-2008, 01:43 AM
  #56
Theking's Avatar
Car: 1989 IROC-Z
Correct you push it down the intake all the way down, then its sealed right, no need for C clips.
heres a pic from my install how it shall look when its installed correctly, the left one is pushed down and correctly installed:
Old 09-03-2008, 12:33 AM
  #57
TPI86TA's Avatar
Car: 88 GTA
Thank you guys fo all the help. Now i have a new problem. The connector for my fuel pump, the one that is mounted ontop the pump assembly, came apart on me. The push ring isnt holding and i triied new ones but the connector is so chewed up they wont grab it. Any suggestion or maybe where can i get a new connector. Thanks....Al
mike_c
08-27-2015 04:32 PM
Jae992
08-27-2015 09:07 AM
86IROC112
08-21-2015 07:20 PM
Bryan F
08-18-2015 02:28 PM
Quick Reply: Bad Injectors???
