SLP Runners ported, whoops!
Old 11-19-2001 | 01:31 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula, '95 Formula
Engine: LC9 , LT1
Transmission: TKX , 4L60E
Axle/Gears: 3.50 9" , 3.23 10bolt
Hello,
I bought a set of SLP siamese runners, and noticed some of the ports wern't completly
round, so I ported them, and opened 'em up a tad.
I was talking to SLP today about throttle plates, and mentioned that the ports wern't completly round. They said "Yeah, believe it or not it gets rid of turbulance".
Now i'm kinda wondering if porting them was
a bad idea.
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters, Summit 1.5 roller rockers, World Products Sportsman II
2.02/1.60 heads, Edelbrock TPI Intake, Cloyes Double Roller, timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs gauge, A/F ratio gauge.
http://www.joesperformance.com
-- Joe
Old 11-19-2001 | 03:01 PM
tpi_roc's Avatar
Turbulance helps fuel atomization
(thats your new excuse now anyways)
Old 11-19-2001 | 03:11 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I wouldn't worry about it. I'm not really sure what they are telling you, and keep in mind that the people you talk to on the phone may or may not know what the he11 they are talking about, but it is hard enough to feed a 355 (or larger) engine through a long tube runner setup. So any porting you do is gonna be beneficial for your setup, with the large cam and better heads with bigger valves that are better suited to higher rpm power, as it will broaden your power band.
my $.02
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old 11-19-2001 | 05:30 PM
anesthes's Avatar
Engine: LC9 , LT1
Hi,
THanks for the responses.
I found it kinda weird but, I was like "ok.."
then I hung up and was like. Hrmm.
I figure tho that a airfoil nad 52MM tb will help next.
-- Joe
Old 11-20-2001 | 12:55 AM
Drakar's Avatar
Better fuel atomization ????
TPI is a Dry flow, so that wouldn't work. Port them big sales people are stupid plain and simple.
Hence there are tech departments and sales department.
Sales = smoke up ***
Tech = Why the **** you do that it worked fine before
Port more if you can more = better.
ok im done for now.
1989 Trans Am GTA, Gutted air box, K&N, Koni Sports
MoJoe
Members Camaros
31
10-06-2021 06:38 PM
Linson
09-25-2021 07:55 PM
no green
01-09-2016 09:22 PM
Royal_Z
09-30-2015 08:45 PM
Dragonsys
09-25-2015 03:51 PM
Quick Reply: SLP Runners ported, whoops!
