What exactly is spark knock?
I am having a clickin sound in my engine, and people tell me it may be spark knock. What exactly is that, and what are the problems that come from it. How do test to see if it is spark knock?
1986 Metallic Blue IROC-Z
80k miles, 305 TPI
Mods:
-Edelbrock Hi-Flow baseplate
-Dynomax Cat-back
-gutted MAF
-K&N's
-airfoil
-shiftkit
80k miles, 305 TPI
Mods:
-Dynomax Cat-back
-gutted MAF
-K&N's
-airfoil
-shiftkit
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
You really have to listen closely and inspect things. Motors make all kinds of strange noises. Rocker arms tick, valves tick, pullys clank, etc.
Knock usually doesn't accur at idle. so if your ticking at idle its most likely something else.
Exhaust manifold gaskets tick a LOT. Hell, my headers even tick. (never seal).
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters, Summit 1.5 roller rockers, World Products Sportsman II
2.02/1.60 heads, Edelbrock TPI Intake, Cloyes Double Roller, timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs gauge, A/F ratio gauge.
http://www.joesperformance.com
-- Joe
-- Joe
-- Joe
Knocking is when the fuel in the comubstion chamber ignites too early due to timing too advanced or low octane fuel, it forces the piston back down causing the knocking sound. A way to test for knocking is to monitor your timing, when you hear a knock the computer should retard it if your knock sensor is working properly.
A clicking at idle could likely be bad oiling to some component or possibly something broken. Is it a tapping sound or an actual clicking? Exhaust leaks will click, and will become louder with higher rpms. If something is broken it will not become louder, just more frequent. Low oil levels or insufficient oiling due to low pressure or a clog or something would also become more frequent with higher rpms.
Maybe you need to try some better header gaskets Joe
Hey,
Yeah no kidding. I keep saying I'm gonna replace 'em but I end updoing other things.
RedLeader289
05-28-2019 01:47 PM
bigjay89gta
10-15-2015 08:04 AM
HoosierinWA
10-07-2015 10:15 AM
efiguy
09-27-2015 01:30 PM
