fuel pressure/vacuum pressure
Car: '89 IROC
Engine: 350 TPI 5.7L
Axle/Gears: axle?? got me.. 3.73:1 gears
wondering what range my fuel pressure should be reading, with car off, and running.
also what is the best port to use to check my vacuum pressure, and where should that normally read.
'89 iroc 305TPI
'89 iroc 305TPI
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: fuel pressure/vacuum pressure
Not sure about what the vacuum reading should be, but fuel pressure should be around 43PSI with the engine off and key forward, and around 38PSI with the engine running, at idle. As RPM goes up, it will gradually increase to 43PSI as vacuum decreases.
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Most any of the vacuum ports can be used. If it's TPI, the one back by the EGR on the passenger side is fine. It should be 18-20" at a warm idle
R3500
08-17-2015 12:16 PM
92camaroJoe
08-13-2015 06:07 AM
