strong gas smell need help quick!!!!!!!!!!!!!
When i start my car there is a strong gas smell it does not come up through the car it comes out the rear my engine is a 350 tpi the last guy i took my car too told me my fuel injector was stuck open is that what could be causin this problem cause my car smells like a skidoo. is there any way to get it unstuck and would it cost alot and is it worth it to get them all done or should i get new accels?and what lbs/hr does a stock 350 tpi run for fuel injectors?please reply soon.And what would it cost to get my fuel injectors redone or whatever they can do to them?
I dont have a lot of experience, but from what I have read the 350 tpi takes 22lb injectors. If you are not planning on doing a lot of performance mods that will require more fuel I have heard a lot of people suggest having them cleaned and flowmatched. I dont remember the company but their is one online that does it and caries a stock of injectors so that you dont have to wait for your specific injectors back. Maybe someone will post that adress if that is what you decide to do.
Car: 85 Camaro SC
Engine: V6
You should get that fixed as soon as possible.Today at work I was taking apart a LT1 intake that caught on fire.It was leaking as well and got too hot and melted everything and destroyed everything under the hood.
my car has been burning hot and i thought that it was just normal the guage reads fine but you can feel the heat coming off the exhaust from up under the car i thought it was normal but now that you mention that it could just be my car gettin hot. could i have hurt the engine i drove it all summer like that and it was like that when i bought the car?could it be hurt bad?
