How far does the knock sensor need to be in the block??
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I just put my new engine in my TA and I went to put the new knock sensor in and I can't get it to screw into the block all the way. I'd say it might be half way in. It's tight and I don't have the proper size wrench as it is anyhow. It's not a 3/4 and not a 7/8 so I'm guessing it's metric... unless it's a 13/16. Do you think this will be ok?? Will the knock sensor work properly this way or should I find a way to screw it into the block farther? Thanks in advance.
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Current Project: upgrade to a 355 TPI, 6" rods, 9.7:1 Compression, Stock TPI ported, 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech hot coil.
1986 Trans AM
305 TPI
4 Wheel Discs
Completely Stock
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
The torque spec for the knock sensor is quite low, like 14 ft-lb of torque, so you don't need to try and bottom it out. As long as it's not leaking and you don't grossly exceed the torque spec, it'll be OK.
Greg Westphal
'87 IROC 355TPI/A4
Greg Westphal
'87 IROC 355TPI/A4
