Few TPI questions
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Few TPI questions
Ok, my car is not a true L98, its been made this way, so get that out up front.
PVC. I see a true L98, the pvc is in the drivers cover, goes to the base intake. Then its "breather" comes from the TB to the pass cover. Now, my pvc is in the pass cover and goes to the TB. Then a chrome breather in the drivers cover. Now one would think this would create a vac leak. But I've removed and plugged the TB and it doesnt change the way the car idles. Only thing I have noticed is that I get a dab of oil in the intake(when its connected). I have thought about trying to get an inline filter or something of the sorts to keep oil out. Any thoughts?
Air intake. I have the factory dual snorkle. I have now seen how much it heats up air coming thru. Have read how restrictive it is on a v8(yet perfect for a v6). I have searched on threads about DIY intakes. I'm not liking the routing I have seen so far. But I have an idea for one. But I need some really good pics of a TA/Firebird intake canister where the filter is round and goes in, and someone point me, or provide some? Also, what is the restriction on the bird? The canister, the elbows, what?
Injectors. I have read that the ford blue top 24# injectors are the favored upgrades. Is that the F55E-A2D ones?
What are some average 1/8 mile times for a somewhat stock L98?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Few TPI questions
If you had the PVC connected to the original intake port with your breather then you would have open vac leak as air through breather is not metered as it is if sourced from TB port.
Sanjay
08-12-2015 03:41 PM
