How big is too big with a CAM and a TPI?
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Will a cam with 234/244 intake/exhaust duration (at 0.050) on a TPI SD work? The heads are darts. The intake is stock TPI except for 58MM TB, SLP runners, ported upper plenum. 30lb injectors. AFPR.
Just trying to get the engine to idle. Chip is custom from Fastchip.
Mark.
Mark.
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: How big is too big with a CAM and a TPI?
High duration cams are hard to tune. Plus, the specs you show has 10* between the intake & exhaust duration, I think that is the most that i have ever seen. I would suggest 234/240. Also, you need to select the LSA, I suggest nothing lower than 114. This cam size is good for a 383. If you are saying that this is your cam for a 305, I think that you are why over cammed!
You might want to talk to someone who tunes 3rd gens. Post this on the tuning section here, make a connection between this cam and tuning this cam. See what responses you get.
there are some tricks to tuning big high overlap cams on SD cars. There is a sticky on DIY board i believe
BUT that cam is big for a 350. If a 383 or larger you can get away with it. Dont worry about the large duration split, that wont hurt much.
Whats the LSA on that cam? duration specs looks like the Performer RPM roller cam and i think thats on a 110. that will have some overlap but definately doable. You could aways run open loop if you cant get it to idle in closed loop. BUT mail ordering a tune for that setup will be hard to do. Be prepared to send it back multiple times til its close enough
Guest
Posts: n/a
Yea... is that a 350 or... *gasp* a 305? LSA?
Its always possible, just the further you go from stock and closer you get to past the 225-230 range on intake duration the more difficult it is to get it right. A mail order tune is going to get you mail order driveability.
Engine: TPI(s)
Sorry ... thought I put "383" in my posting. Must have deleted it.
The cam is an older crane. 0.488/0.510 lift. The card does not have overlap on it or lobe centreline or anything. Looks like I'd have to use some math to calculate it.
Car: 82 Z-28
Engine: 383 TPI
A stock TPI intake on a 383 will choke it above 4000 rpm. If you gonna keep that intake i'd be looking for a shorter dur cam. Even with a aftermarket high flow intake, the dur is still too much IMHO.
Lingenfelter designed a cam especially for 350 TPIs.
It's dur was 211 and 219 at .050".
It's a great cam to take advantage of the tuned intake runners. Makes for a very torquey, fun-to-drive street car.
Car: 88 GTA "Cocaine"
Engine: 350 tpi
that cam is going to need a stall and you are going way past the stock tpi powerband
you need the aftermaket tpi section for advise
ie shorter runners and more pleneum
Guest
Posts: n/a
Do you have any datalogging equipment? You're gonna need it.
ambainb
04-25-2016 09:21 PM
Sanjay
08-12-2015 03:41 PM
