Fuel pressure = 100???
Old 05-10-2008 | 11:00 AM
Raiden's Avatar
I have had a serious idle problem. Due to recent gas prices, I had swaped out my 30lb injectors for my 24lb injectors and then increased the fuel pressure. When I drove my car it ran ok, but I noticed my car started to have an idle issue. It started to cut out and die. Checked for codes, vacume leaks, IAC....nothing found! I had fuel coming out the vacume line off my fuel pressure regulator and my fuel pressure was 100 when checked the fuel pressure. I swapped out the fuel pressure regulator diaphram & I swapped my injectors back to the 30lber's. Start my car and my car still will not idle! I pull the vacume line off the fuel pressure regulator and no fuel is coming out, but the car will idle. I check my fuel pressure and it's reading 100psi! When I connect the vacume line back on to the fuel pressure regulator, the car dies??? I searched for high fuel pressure with our search option and I have found noting on this situation????? HELLP!
Old 05-10-2008 | 11:43 AM
Raiden's Avatar
Re: Fuel pressure = 100???
Key on Engine on = 100 psi fuel pressure
Key on Engine off = 40 psi fuel pressure
Old 05-10-2008 | 11:56 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Try an new fuelpressure gauge, then check your fuelpump, and lower the pressure again, over 50PSI is real bad for your stock fuelpump. it will cause damage to the pump, 100PSI really not good.
Old 05-10-2008 | 05:07 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Check for a plugged/pinched fuel return line. 100# is the pump at max pressure, no regulation (check regulator internals).
40# at key off is the check valve pressure, could be anything.
No/low vacuum higher fuel rail pressure, high vacuum lower fuel rail pressure (+/- 5#). 43.5#-38#
Old 05-10-2008 | 06:04 PM
Raiden's Avatar
Well, The BRAND NEW fuel diaphram I got from autozone has a leak that is dumping fuel out the vacume port. I don't even thing the diaphram was on the running car more than 5 minutes total! I would not doubt that was the problem all along!
Old 05-11-2008 | 06:54 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Originally Posted by Raiden
IDue to recent gas prices, I had swaped out my 30lb injectors for my 24lb injectors and then increased the fuel pressure.
Changing to the 24#'s and raising the fuel pressure is real close to the 30#'s and lowering fuel pressure. If the blm's are between 108 and 160 (closed loop) there will be no change in the fuel comsumption.
Old 05-11-2008 | 08:16 AM
Theking's Avatar
Car: 1989 IROC-Z
Old 05-11-2008 | 11:03 AM
Raiden's Avatar
In theory, I would agree with you. However, when I run my 24's vs my 30's there is a significant difference in gas mpg. I can maybe get 10mgp with the 30's. Granted, I have a lead foot when I drive it When I run the 24's, I get an average of about 16-18mpg....driving it the same. I Just can't wait to get it running again I'm going to check the fuel lines for kinks...which I've found none.
What do you guys think about me using an air hose to purge out any clogs in the fuel lines? Just a thought???
Thanks for the help!!!!!!!!!!!!!
Old 05-11-2008 | 12:53 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Blow the return line back to the tank. Listen for the hiss at the fuel cap (don't smoke).
A word of wisdom either the 30# are too rich (check Afr) or the 24# are too lean (at wot) the first wastes gas and power, the second melts pistons.
Old 05-11-2008 | 01:20 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Also, bad gauge, Don't think stock pump capable of
putting out 100psi let alone the 255s
Played with mine while tuning and think 58# was the
peak and thats with a 340M in the tank.
JMHO
Later
Old 05-11-2008 | 04:32 PM
Raiden's Avatar
My fuel pump is a walbro 255lph pump. And ya don't have to worry about me smoking That would be bad...Kaboom!!! My car runs really strong..really strong with the 30's! If I pump my fuel psi up to 52, the 24's do ok, but I notice a huge power difference! I need to get it tuned for the larger injectors!
I just hope my only problem is my fuel pressure diaphram! Thanks for the help!
Old 05-14-2008 | 12:57 AM
Raiden's Avatar
My FMU was not working right. I disconnected it and fuel pressure is where it should be. Thanks for your help
92camaroJoe
07-29-2023 07:57 PM
mdtoren
08-16-2015 05:45 PM
92camaroJoe
08-13-2015 06:07 AM
Kaweh
08-09-2015 02:54 PM
Quick Reply: Fuel pressure = 100???
