LT1 throttle body ?? what size throttle bores??52mm?
anyone know what size the throttle bores are on a LT1 T/B?
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
formerly BW 9-bolt w/3.45 gears(broke it)
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
87 IROC-z 305 TPI
thanks ED from what i have heard so far they are 48mm which also leads me to beleive that my 305 TPI should be fine because there are LT1`s doin great with a 48mm
87 IROC-z 305 TPI
87 IROC-z 305 TPI
Car: 04 GTO
Transmission: M12 T56
Oh yeah man, you don't realistically need to start thinking of TBs till you're in the 12s, or at least real low 13s. The only reason you see so many slow cars with TBs is cuz it's one of those easy to do mods that somebody who wants to blow money goes for so they don't have to get dirty doing a cam swap, etc.
Terrell351
06-13-2021 01:13 PM
mdtoren
08-16-2015 05:45 PM
