another MAF problem
Car: 1987 IROC-Z Camaro
another MAF problem
I believe my MAF is bad.....(car falls on its face when taking off, runs good at higher rpm) but anyway should I just replace the stock one or is there a performance one that I should just buy anyway?
Re: another MAF problem
If you disconnect the maf, how does it run during idle ? worse ? no difference ? if theres no difference it may be bad. but if it runs worse there may be a change for your maf... its not fun changing it if you not 100% sure its bad.. it cost alot of $$$..
when it is unplugged it runs slightly better......runs fine at idle.....still not really drivable......yeah I think I am going to check the TPS sensor this weekend I read somewhere that it can throw the MAF off
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
