Oil in my throttle body?
Old 04-19-2008 | 03:55 PM
Son of Anarchy's Avatar
Car: 1987 Camaro IROC-Z
Engine: 383 Carbed
I have and 87 IROC-Z 5.0 TPI. Lately Ive been having problems with my car idle-ing. So my I took it to one of my friends who also has a third gen. He told me to take off the intake so I did and to my surpirse there was a little bit of oil in the throttle body. We tried to located the oil leak, but we cant seem to find it. Where can it becoming from? Any help would save me the cost of having the engine rebuilt later, thanks.
Old 04-19-2008 | 04:16 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Oil in my throttle body?
probably through the breather line, the vacuum hose that goes to the passenger side valve cover. Pull it out of the valve cover and look inside it, there should be a little flter in it. Mine was missing, and I was getting a little oil in the TB too.
Old 04-20-2008 | 02:07 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
You might also make sure that the PCV side of the system is working.
1992 Trans Am
05-10-2023 07:19 PM
86White_T/A305
08-17-2015 12:16 AM
mdtoren
08-16-2015 05:45 PM
bamaboy0323
08-15-2015 07:20 AM
Quick Reply: Oil in my throttle body?
