tbi wiring harness
Old 10-03-2001 | 02:30 AM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
tbi wiring harness
I originally had a tbi 305 in my camaro and put a 350 carb in it now with all the wires still in tack and in the car. I want to convert to tpi this winter. I was wondering if I could plug in the all the wires that run from the interior of the car climate controls etc, to the tpi computer. Also do I need the speed sensor hooked up for the tpi or will it mess up the performance cause its not hooked up, cause my camaro is a 91 with the electoric speed sensor and the tpi i have is off an 87 that uses a speedo cable. Thanks for any help!
1991 teal camaro RS rebuilt 96 350 marine motor, comp cam, accel ignition,8mm accel plugs and wires, hedman headers and y-pipe, and rear end with 4.10 gears. Stock 700r4, best 1/4 time 14.6
Old 10-04-2001 | 12:27 AM
airdeano's Avatar
the climate contols can be run independent
of the TPI computer.
if you have to emmissions devices then youll
needto enable the VSS. youll need a 4k pulse generator
available for cable drive speedos. the output
of the stock carb/tbi is a 2k pulse.
if you dont have to have emmisions.. nix the
input.
if you have a 350c/200/700r4 youll need TCC control.
you can have an external switch for this.
camaro11j
09-19-2018 09:49 AM
crt454
Interior Parts Wanted
06-23-2017 03:25 PM
TheJoeY88
12-31-2016 08:30 PM
Ikes 91Z
12-09-2015 04:49 PM
Reddeath210
10-06-2015 09:20 AM
