LT1 intake question
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
LT1 intake question
How does an LT1 intake perform on what would normally be an LB9 (305)? The cam in the LB9 is the same as the 350 cam, correct? Anyone know?
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
A LT1 intake doesn't fit a LB9 or L98 for that matter because the LT1 uses reverse cooling.
The 305 cam is different than the 350 cam..UNLESS the 305 came with a T5..i believe that setup got the L98 cam...don't quote me though...
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Tony
<font face="Verdana, Arial" size="2">Originally posted by fly89gta:
</font>
</font>
Just ask John Millican.
Later,
Vader
Justice and Freedom will Prevail
Adobe Acrobat Reader
[This message has been edited by Vader (edited September 30, 2001).]
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
When is he going to make a write-up about it im getting kinda Antzy.
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
91 Z28 5.7l Camaro
more to come....
My 91 Z28
1 Post
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Thanks Vader for posting the pic, you beat me to it.
I'd say any combo is possible if you think it out all the way through in advance and do lots of research. I did and swapped it in a weekend.
The tech is coming, maybe this week. I've been busy all week.
<font face="Verdana, Arial" size="2">Originally posted by 90Iroc:
How does an LT1 intake perform on what would normally be an LB9 (305)? The cam in the LB9 is the same as the 350 cam, correct? Anyone know?</font>
The cam difference between a 305 TPI and a 350 TPI is quite a hot debate. Its been accepted that 90-92 TPI all have the good 350 cam. Its also accepted that the 87-89 305 TPI automatics have the peanut cam, while the 305 TPI 5-speeds and 350 automatics have the good cam. But this hasnt been proven for sure, yet.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
<font face="Verdana, Arial" size="2">Originally posted by Kevin91Z:
</font>
</font>
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Thanks everyone, I was just curious as to how it would perform if I were to do like John. I didn't mention it before, but I do have the T-5 tranny, therefore relegating me to the "good" cam. Would the cam theoretically even play a crucial part in that setup (305 LT1 w/"good" cam)?
[This message has been edited by 90Iroc (edited October 01, 2001).]
WE BETTER START A NEW SUBJECT IN THE BOARD CALLED "LT1" and it would be located right under "TPI" so john were there any holes that did not line up with anything but did not matter like the reverse cooling holes etc.
Hoping not to burst your bubble but to make sure you do have the "good" cam, check for RPO G92 to make very sure, that will get it for you. Also swapping an LT1 intake, well that seem like a good idea for a 350, it wouldn't be for a 305 as TPI was developed for a 305 and an after though on the 350. But If you have time, money and an LT1 intake, go for it, would be cool to see the results and how it looks.
1989 Trans Am GTA, L98 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27,
- K&N Air Filter
- Dynomax muffler
1992 Camaro RS, LO3 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel - Sold
- K&N Air Filter
Honda engines ROCK, I have one on my lawn mower but I still have to push it.
- K&N Air Filter
- Dynomax muffler
- K&N Air Filter
1 Post
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by ImportsRsloths:
WE BETTER START A NEW SUBJECT IN THE BOARD CALLED "LT1" and it would be located right under "TPI" so john were there any holes that did not line up with anything but did not matter like the reverse cooling holes etc.</font>
Remember I used the LT1 intake not heads. Yes, there were bolt holes that did not line up with anything because the bolt pattern is differant. It does not matter though, I just filled them with epoxy(JB weld) and painted the intake red. Turned out great.
1 Post
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by Drakar:
</font>
</font>
Ha ha, we already knw how it looks, the pic is in this topic. It would be funny if you did it with tall valve covers as the covers would be higher then the intake. I used normal covers and they're the same height as the intake.
Hoping not to burst your bubble but to make sure you do have the "good" cam, check for RPO G92 to make very sure, that will get it for you. </font>
Do you think someone like AFR, who makes both L98 and LT1 style heads, could make a set of heads with the L98 water passages but with the LT1-LT4 style bolt patterns? Maybe they could also tap into the water passages so the the water crossovers could be done externally with hose or tubing. Any thoughts?
<font face="Verdana, Arial" size="2">Originally posted by bw88GTA:
Do you think someone like AFR, who makes both L98 and LT1 style heads, could make a set of heads with the L98 water passages but with the LT1-LT4 style bolt patterns?</font>
<font face="Verdana, Arial" size="2">Maybe they could also tap into the water passages so the the water crossovers could be done externally with hose or tubing. Any thoughts? </font>
Car: 04 GTO
Transmission: M12 T56
Do you think someone like AFR, who makes both L98 and LT1 style heads, could make a set of heads with the L98 water passages but with the LT1-LT4 style bolt patterns? Maybe they could also tap into the water passages so the the water crossovers could be done externally with hose or tubing. Any thoughts? </font>
As to the water passage location, thats an interesting idea. I don't know if the outlets 'have' to come from the front, i know lots of race cars plub coolant lines to the back and even center of the head. Could make for a REALLY trick looking install.
...ed
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
I don't think it would have to be a hybrid head. I suspect that AFR casts the head, then does final machining on a CNC mill. including locating and tapping all of the threaded holes. Since they have already developed the CNC programs to machine virtually identical castings (aren't L98's and LT1's virtually identical in overall dimensions?), wouldn't it simply be a matter of adapting the LT1 program to the L98 head "blank"? Maybe it is just a matter of adding some tapped holes to the heads to facilitate external plumbing. It's just a thought, but I can't see this as being that complicated, maybe AFR could do it as a special order. Brodix (I think) used to offer a reverse flow kit that did something like this. Of course, there are still plenty of other modifications that would be required use the LT1 intake. It's just a thought.
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Thanks to all of you!! Yes my car is a 1990 Iroc/Z 305 TPI G92.
Modifications list on my Iroc:
Engine Specifications and Relevant Information
Displacement: 305 Cubic Inches (5.0 Liter)
Induction: Tuned Port Injection
Rear Axle Ratio: 3.42:1
Transmission: Borg Warner World Class T-5 Manual
G92 Performance Package
N10 Dual Catalytic Converters
Z28 Performance Package
Engine Modifications:
K&N Conical Throttle Body Clamp-on Air Filter
160 Degree Thermostat
Secondary Fan Switch By-Pass
MSD Cap, Coil, 8.5mm Wires, Rotor, and 6A Ignition
Accel HEI Module
JET Adjustable Fuel Pressure Regulator
JET Fan Switch
Quaker State Hi-Performance Oil
Computer Modification:
Ed Wright (Fastchip.com) Stage 2 Performance Chip
Interior Modifications:
Macewen White Gauge Face Overlays
Auto Meter Phantom Oil Pressure Gauge in A-Pillar
Hurst Comp/Plus Shifter
Kenwood CD player and 7x10's Mounted in Rear Cargo Well
Exhaust Modifications:
Gutted Catalytic Converters
3" Intermediate Pipe
Flowmaster Crossflow Muffler
3" Chrome Tail Pipes
Suspension Modifications:
Addco Sway Bar End Links (Polyurethane)
Gabriel Hi-Jacker Air Shocks (Rear)
(Will soon install a Spohn Tubular Panhard Bar)
Exterior Modifications:
5% Window Tint
GTS Taillight Blackouts
Black GTA rims
Best 1/4 Mile Dragstrip Pass To Date:
Solo:14.739 Seconds @ 94.42 MPH
With Passenger:15.009 Seonds @ 93.51 MPH
A Run of 14.5 Is Possible, But I Have to Wait for My Shifter Springs to Arrive (Mine Are Missing for Some Reason). The Run I Know Which Should Have Achieved This Was Against a Mustang Who Ran a 14.865. I Was Ahead By An Entire Car-Length the Entire Run Until My shifter Hit the Gate For Fourth Gear, Causing Me to Miss the Gear and Grab a Very Disappointing 15.810. What Makes This Story Even Worse to Tell, Is The Fact That I Believe I Had My Best Reaction Time On This Run; a .605 Second Reaction.
Accel HEI Module
JET Fan Switch
5% Window Tint
Black GTA rims
</font>
</font>
Your sig is WAAAAAY too long *cracking up*
thats why an LT1 is designated as reverse flow.
coolant goes from the heads to the block.
earlier systems flowed from the engine block
to the head and to the radiator. racers tap
the
rear and exteranally balance the flow to cool
the heads off quicker. notice several intake companies
are offering rear coolant passages.
the
