elimination of VATS from the e-prom?
I have a chip burner and would like to know if anyone knows or has the code to take out VATS from the chip? I am installing a '88 engine into an older truck and want to take out as many wires as possible.
Also, how to reprogram to speed density to take out MAF?
to burn a SD chip is a way different chip.
the MAF systems used a 16k $6E file definition.
the SD used a 32k $8D file. so there is no
MAF to burnout.
if you have access to tuner cat uncheck the
VATS box, save file, burn chip.
you may beable to search the DIY burner
board for the VATS address.
airdeano
MAF to burnout.
airdeano
Pac J
05-17-2020 11:44 AM
