check engine light comes on after driving for a while
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
my engine light comes on after driving for mabye 30 mins. Tried to get it scanned but my lighter dont work so we cant find out any ideas why? Only mods i have is i cut out cat and just have a muffler there rest of exhaust is off for now.
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: check engine light comes on after driving for a while
More than likely the modifications you've done to the exhaust system are affecting the 02 and egr, causing the check engine light to display. But, instead of guessing, you can get it scanned at most auto parts stores for free.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
You can also use a paperclip to read the codes. There's a short article about it here: https://www.thirdgen.org/service-eng...ht-error-codes
Hope this helps.
Lou
Hope this helps.
Lou
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
For whatever its worth, my engine light kept coming on in my daily driver (Yukon) and the owner's manual said to check for a loose gas cap.
I did - it was loose - tightened it - the light went out in 60 seconds. Hasn't come on again in months.
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
well i jsut got gas an it wasnt anyhting like that. also i did go to advance and they couldnt check cause my cig lighter dont work so they couldnt get power
Engine: TPI
As I suggested above, try the paperclip.
No need for a cigarette lighter, no tools needed, just get a paperclip (or a piece of wire). It doesn't get easier than that.
Once you know the code, the guess work is over and you won't have to run around your car anymore, loosening gas caps, opening and closing doors, topping off coolant or oil etc.
Try it, it only takes 2 minutes.
Lou
Lou
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
is there anyway doing this wrong could mess anything up??
Car: 1986 IROC-Z28
mine always comes on the 1st time i accelerate, and stays on until i shut the car off. the cycle is constantly repeated everyday
Car: 89 Formula
Engine: 383 SBC/HSR
Mine flutters back in forth, it has a mind of it's own. I guess that's what happens when you get rid of the EGR and don't burn a chip.
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Engine: TPI
Don't worry, you can't destroy your car that easily.
If you stick the paperclip in the wrong holes in the connector, you might blow a fuse or something. But that's about it.
If you simply follow the picture and insert the paperclip in the two rightmost holes in the top row of the ALDL connector, you'll be ready to read the codes by watching the CEL flash. Follow the article on how to count the flashes correctly.
Hope this helps.
Lou
Hope this helps.
Lou
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
ight ill try that. also should i wait till the light comes on to try it?
Engine: TPI
No need to wait for the light to re-appear. The fault codes are stored in the ECM memory.
Let us know what you find.
Lou
Lou
