simple tpi assembly question
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
hey all,
I have had my tpi assembly put together for almost a whole week (yaay me ). now i need to tear it back down due to crap injectors. do i really need to order new gaskets (large diameter) or can i get away with using them again? maybe a little of that high tack stuff to help the seal?
Thanks,
Thunder
Thanks,
Thunder
Car: 89 Firebird Formula 350
Engine: 350 tpi
Re: simple tpi assembly question
I agree. Get new gaskets. I did the same thing with mine. If I remember, Advanced sells an entire set of Felpro gaskets for around $40. Also make sure you check and carefully cut out any areas with excess material. It could restrict air flow and we all hate that. Good luck.
Engine: 5.7L w/hsr
damn. thats a freakin bummer. i gasket matched the damn things... guess i learned my lesson. test the injectors FIRST.
does anyone have an easy way to open the gaskets up?? i have a felpro set, and i have an edlebrock set, both of which are metal impregnated. this of course makes them a bitch to modify. a dremel sanding wheel just gets chewed/cut up, and using a deburring tool just jerks it out of your hand. my ports are all opened up to 1.75, which requires alot of modification to the standard gaskets
Car: 89 Camaro RS
Engine: 350 TPI L98
Transmission: 700r4 w/ shift kit and 2500 stall
Axle/Gears: 2.77 one tire fire!!
Maybe try the carbide dremel tool. It's made of metal and looks similar to a roto-zip bit. It won't get clogged up or beat up like the sanding ones. I haven't used it on a metal impregnated gasket but I have used them on solid metal and they work great. Should go through a gasket like a hot knife through butter. Good luck.
Steve
Steve
Engine: 5.7L w/hsr
you know what else is awesome?? the mr. gasket #146 large diameter set is no longer available due to a manufacturing mistake... with no lead time on when they are back in stock
does anyone else make a decent 1.75" diameter gasket set for tpi runners?
Car: 89 iroc
Engine: l98
Transmission: tremec
did you know you can change injectors without removing the runners.\
Engine: 5.7L w/hsr
not with the edelbrock runners... they are larger and hold the fuel rail much tighter than the stock runners. if you have a trick to do this, please hook me up... that would make my life suck much less right now
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Steve
Steve
Fast355
12-02-2016 06:33 PM
Sanjay
08-12-2015 03:41 PM
