iac motor/super ram question
When I start my car, the idle jumps around a couple hundred rpm, and sometimes revs up to 1300ish in park, from the 1000 it is set at. I just replaced the o2 sensor, entire ignition is new. TPS seems fine. No vacuum leaks. What happens when the IAC goes bad?
Also, Im trying to sell my super ram plenum and runners, it could use new gaskets, has less than 10 miles on it, one 1/4" 12pt bolt missing. How much should I try to get for it?
[This message has been edited by rezinn (edited September 20, 2001).]
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I'm looking to buy if the price is right
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Flowmaster Exhaust
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
Can you guys tell me the symptoms of a bad IAC?? My car doesn't idle with it disconnected, so I can't set it right. It idles alright, but too low with it connected.
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
What are you asking for your Super Ram and why are you selling it?
Mods: ZZ4 engine w/stock TPI, adj, fuel pres. reg., MSD 8.5, HI6S ign. w/ PS-91 coil, K&N filter, TPI air foil, Hooker comp. shorties, American Thunder flows. 160* stat., TB bypass, 3"cowl, bat. relocate, AC delete, stock T-5 w/ 3.42 rear, ported plenum, 24# inj.
This isn't really tech.. but we put the 350 in the el camino and the 305 in the camaro, so I don't have a use for it. Im moving to college in 2 days to further complicate things. I put up an ad in the classifieds but apparently it didn't work, even though I can edit it.. I was going to ask 600 obo.
I got the car to idle with the IAC connected, and adjusted the tps.. the idle still doesn't want to stay right though, and jumps around a lot. I guess its just the cam though.
