LPE219 or LT4 hot cam on a 383 SR?
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
I was set on a LT4 hot cam...but now im not so sure....here is what im planning:
-383 with forged internals
-AFR aluminum 195cc Street Heads, Angle Plug w/heat riser, 68cc
-Super Ram intake
-Around 10.1 compression
-Want best gas mileage possible
-Running atleast 12s (11s would be nice) in 1/4
-Daily driver
-Needs to pass TX inspection/emmisions
Which cam should I go with? Here are the specs of the two:
LPE219
Dur @.050": 219/219
Lift w/ 1.5: .525"/.525"
Lift w/ 1.6: .560"/.560"
C/L: 112
LT4 Hot Cam
Dur @.050": 218/228
Lift w/1.6: .525"/.525"
C/L: 112
RPM Range: 1600-6000
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cats Coming
More to come.
-Super Ram intake
-Daily driver
LPE219
Dur @.050": 219/219
C/L: 112
LT4 Hot Cam
Dur @.050": 218/228
C/L: 112
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
I'd go with the HOT cam. That LPE cam is more for a 350 engine. The HOT cam was also designed for short runner intakes (like the super ram).
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
1 Post
Car: 1992 Z28
Engine: 355
I would and did go with the LPE "219" cam. It has proven itself to be a strong performer. It will also pass the "sniffer" The SR is not a short runner intake. It may have shorter runners than the standard TPI but it is by no means a short runner system.
92Z28
89GTA
92Z28
89GTA
Engine: 305 TBI
well the site (http://www.lingenfelter.com) does say the lpe219 cam is for 350-409 engines or something like that........but its also like 3x the price of the hot cam....and so Im all confused now.....is the lpe cam really worth the extra $200 or so....for something that seems to be EXACTLY like the hot cam......plus its not like the hot cam is a crappy cam...im actually suprised its so cheap. Just confused.
The reason your seeing the hugh price difference is because the LPE cam says Lingenfelter all over it.. Thats about the ONLY reason. I'm sure the hotcam would work pretty well also.
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Brendan
I think both those cams are too small for what you want. I'd say the GMPP cam thats one bigger than the LT4 HOT, I think its like 224/230 or something like that.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
I agree with Kevin, remember the larger the engine is (C.I. wise), the cam seems smaller in a given engine. eg. you need more cam for a 383 vs. a 350.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.6/1.52 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, Accel 300+ box & coil, Taylor 409 wires, Fastchips custom chip, MAC sub frame connecters, Lakewood LCA & Adj. Panhard rod, SLP 2500 stall, 3.42 rear gears, 1LE aluminum driveshaft, white face gagues, and NOS!
1 Post
Car: 1992 Z28
Engine: 355
The LPE roller cams are made from billet steel which may contribute to their higher cost. That and the box says "Lingenfelter" on it. Your best bet would probably be to call all of the better cam manufacturers like Comp, Crane, Schneider, etc and see what they recommend.
92Z28
89GTA
92Z28
89GTA
1 Post
Car: 1992 Z28
Engine: 355
Oh yeah, the cam card with the "219" cam actually lists the duration as 218. Just a bit if useless information for ya.
92Z28
89GTA
92Z28
89GTA
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
GMPP cams are billet steel as well.
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
1987 GTA L98 MD8
My GTA
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Definitely go with the 219 cam...it's made for the SR. Plenty of guys are running this setup (mostly Vettes though) and they pull low 12s/high 11s on a 383...definitely a hot street combo that passes smog. One guy on the corvetteforum is running high 11s @ 116 mph on a stock block 350, NA using a 219/AFR/SR setup.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Both cams will pass the sniffer.. Both cams are Billet. The 219 cam was made specifically for the SR setup. If you want good gas mileage, and a decent idle, go with the 219 cam.. I ran the 219 with my 383 SR setup with TFS heads that flowed around 258 cfm@ .500 It was a decent cam for the street. The AFR heads are kind of lacking on the exhaust side out of the box, and you might want to consider using a split duration cam to help the exhaust side out a bit. Even though the 219 cam is made for the SR, heads play a role also. If you use the Hotcam, make sure and use 1.6 rockers, because it is .525 lift only with the 1.6 rockers.
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
like kevin g said the exhaust porton the afr's aren't the best i would definatly go with a split dur. cam to help out the exhaust a bit oryou could just go with 1.5's on the intake and 1.6's on the exhaust to get a little bit.....for the money you can't beat the hot cam
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
car has found a new home
she will be relocating soon,thanx to all that were interested and the few who had purchased some of the many,many extra parts i had accumulated over the years.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
best e/t:
gixxer92
09-01-2015 04:32 PM
LT1Formula
08-20-2015 09:36 PM
1988iroc350tpi
08-14-2015 07:52 PM
