Will I see any gain from the Edelbrock base???
Old 09-13-2001 | 12:39 AM
crazyjoe's Avatar
Just curious of just how much of an improvement I would see with this base over the stock piece. I dont plan on porting it out, although I know it would help, but I dont have the tools nor the know-how! So how many horses should I see(approx.) with my current set-up(mods in the sig.)? Would it be worth the money? Thanks for any thoughts on the subject.
'91 TA, 305TPI, mild cam, stock heads ported and polished, ported plenum, SLP siamesed runners, edelbrock TES headers, flowmaster 3" cat-back, 3.73 posi, K&N, custom CAI, hypertech stage II chip, march underdrive pulleys, (1/8th mile: 9.45@74.28mph)
'95 TA, Borla exhaust, K&N CAI, !MAF screen, 160 stat, March underdrive pulley, Richmond 3.73's (1/8th mile: 8.84@ 79.42)
Old 09-13-2001 | 10:21 PM
Dan87IROC-Z's Avatar
I saw a pretty impressive gain with my LPE base. I really don't know how it compares to the Edelbrock, but I would bet you could see a good .3 drop in your 1/4 ETs with it and the mods you have.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old 09-16-2001 | 01:27 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Sounds about right...get the Edelbrock base from Jim Pace performance Parts...cheapest price brand new, $330...The Accel base is a nice piece though. It's also pretty damn expensive!
Old 09-16-2001 | 07:05 PM
Erik formula L98's Avatar
Just by adding the Edelbrock base on my 350 tpi I improved by close to 2 tenths which is close to about 20hp.
Erik '89 Formula 350 TPI
13.96 @ 97 on motor
12.63 @ 111 w/NOS
http://www.geocities.com/formulal98/
Old 09-16-2001 | 08:49 PM
robert1's Avatar
I agree, the experts in their tests say 15-20 hp on a stock 350.
Old 09-17-2001 | 12:56 AM
crazyjoe's Avatar
Hmmm, 15-20 on a 350, I wonder if it would be about the same for my lil' 305? I was wanting to have Ed Wright(or similar) burn me a custom chip too, I really think it would do wonders over this hypertech chip. Hopefully with the base and the chip, I'll be able to knock 2 tenths off my 1/8th mile times. I guess I'll have to wait and see! Thanks for the replies guys.
Old 09-17-2001 | 01:04 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
When I had my 305 TPI, I had a bunch of mods for it like, Headers, pulleys, chip, cat back, K&N's, shift kit, 1.6 RR, and I bought the Edelbrock base and runners and I was slower in the 1/8 mi. I think I dropped a 10th or 2. Just my experence.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.6/1.52 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, Accel 300+ box & coil, Taylor 409 wires, Fastchips custom chip, MAC sub frame connecters, Lakewood LCA & Adj. Panhard rod, SLP 2500 stall, 3.42 rear gears, 1LE aluminum driveshaft, white face gagues, and NOS!
Old 01-07-2003 | 10:11 PM
89transam's Avatar
I realize this post is mega old, but tommarow I will be finishing the install of a accel base. Any guesses on what it will gain?
Basically I have a 383 with sportsmas heads and a full exaust, with my cam I make peak power a 5500.
The intake is completly stock, down to the air filter.
Pac J
05-17-2020 11:44 AM
skinny z
Carburetors
09-30-2015 12:25 AM
ndndndnd
09-28-2015 09:00 AM
Night rider327
09-25-2015 05:47 AM
mrestrictrplate
09-21-2015 12:24 PM
